This post was a little while ago but I would love to hear how you got the best out of this driver, what do you suggest doing?
In case you cant remember it was the RAB-32257
Cheers.
Well i was trying to disturb the balance of soundstage and image and actually made it very large sounding at expense of imaging
That was later made RAB-p after some tuning etc which sounds very nice
You can try RAB-p/pro 1 tubing, damper and zobel in custom iem shell.
The tubing consist of Horn and mouth.
The mouth act as a resonator and shifts the response of 3kHz peak 150Hz back.
Horn helps the treble to gain some boosting as RAB are weaker than ED in treble department.
White damper or brown damper(according to taste)
Zobel helps deloading the driver by fixing its impedance ratio, electrical phase. This makes it more easier to drive, stresses the amp less, which leads to less distortion. It also helps with selection of amplifier(due to very low impedance swings). Noticeable sound difference of zobel are:
1. Better mid clarity.
2. Effortlessness type of feeling
3. Better staging and imaging
4. Better treble shaping.
But Zobel are like garnishing or icing on cake. The major difference comes from tubing and damper arrangement. Zobel effects are very much noticeable but it doesnt change the signature..
@wardy
