Home-Made IEMs
May 3, 2019 at 8:05 AM Post #8,866 of 15,976
All this talk of the polarity of caps is kind of pointless. We're discussing audio signals here. By definition, they are AC. That means that no matter which way you orient the cap, signal is flowing "backwards" through it half the time. Please correct me if I'm wrong, with proof. I do like learning new things.
Signal is flowing backwards half the time, but the question is how does a polarized capacitor behave if signal is flowing backwards? Some of us are not hearing any difference at all, while I convinced myself that I did hear slight distortion with polarized caps. I also read that a cap becomes a short for voltage flowing backwards.
That's why I did investigate.
Turns out: A polarized cap is a capacitor regardless of the direction of current, but it basically breaks if the current flows the wrong way for too long. I think you can use polarized tantalum caps rated 12V or up for CIEMs without problems, according to the NASA paper that should be ok. You probably cannot use electrolytics because they will fail over time.
But of course you can always use two polarized caps in series with reversed polarity or unpolarized caps to avoid any of these risks.
May 3, 2019 at 9:47 AM Post #8,868 of 15,976
Parallel RAB32257 + 11ohm resistor + new zobel with 3.9mH inductance and 22ohms DCR as new standard for measuring and calculating
Flattest impedance, Flattest phase and way better than series parallel
Does this mean you've finalised the zobel for 1 RAB? :beerchug:
Also, has anyone ever heard of/tested 1audio drivers? I just randomly stumbled upon their TB shop, they seem to be imitating Knowles' numbers, but also with some really weird stuff like these dual RAB32257 drivers with 1 combined spout. Not really sure if they're "real" 32257s, just guessing from the name. Seems like a timely listing for everyone testing multi-RAB setups :D
May 3, 2019 at 9:59 AM Post #8,869 of 15,976
I have warbler prelude, jomo Hakka, FIBAE 1, FIBAE 3, Fiio FA1
Friend has FIBAE black.
Single driver needs a lot more tuning but they sound extremely fabulous. They sound more coherent and more stitched in together compared to multi driver.
Yes RAB single driver is perfected for now....just some small tube tuning going on for getting perfect head structure heatmap(tuning soundstage and energy) and acoustic pressure distribution for fatigue free listening and bigger headscape experience.
For dual driver, I have very flat impedance and phase, but it sounds standard.. It doesnt have horn and resonator (muffler) stuff
For now
Well, I think we have talked about advantages about flat phase and linear impedances....but I think, sensei(@piotrus-g ) should throw some light on the advantages of flatter impedances and linear electrical phase. Because he pioneered it
Sensei means teacher by the way(in Japanese)
May 3, 2019 at 10:18 AM Post #8,871 of 15,976
Thanks! Keen to start building it. Just to confirm, according to your last posted spec, the zobel is
Cz = 4.6uF
Rz = 41ohms,
with a series resistor 20ohms?
May 3, 2019 at 10:26 AM Post #8,872 of 15,976
Cz = 4.6uF
Rz = 41ohms,
Zobel is 4.6uF and 41ohms
Series resistor value range from 10ohms to 33ohms
It all depends on taste
And the zobel you mentioned will only work with
RAB32033
RAB32257
RAF driver
The real game will begin with tuning the tubing and dampers like @Choy Wei De
May 3, 2019 at 12:03 PM Post #8,873 of 15,976
I bought a bunch of these from them:
https://item.taobao.com/item.htm?spm=a1z0d.6639537.1997196601.451.340174844g84BV&id=581311508669
...and some "SWFK" drivers, but never got around to using them. Dunno how they sound unfortunately.
May 3, 2019 at 12:18 PM Post #8,874 of 15,976
I am curious how people are terminating the tubes in their shells. I think that is the sloppiest part of my build right now. I have experimented with a single bore and backfilling around the pvc tubes as well as boring each tube individually. I haven't figured out how to get the tube ends to look recessed or super finished. Anybody have any pointers?
May 3, 2019 at 1:13 PM Post #8,876 of 15,976
Not the best way to do it, but if they stick out a little, I use the middle part of the soldering iron and really quickly smooth it over.
May 3, 2019 at 1:14 PM Post #8,877 of 15,976
Man, I am seeing those driver for the first time
It's their original dual drivers. The seller told me they're for mids or mid-highs, but when I told him the graph looked like it'll be good for bass, he said it should be pretty good for bass too...
As I've never tested them I won't know until later :p
May 3, 2019 at 2:04 PM Post #8,878 of 15,976
What I do is I stick the metal tips of syringes into the tubes (they happen to fit perfectly into 2mm ID) and then apply some more resin.
After that I carefully rotate the metal tips out and carefully sand and polish (very careful)
