dhruvmeena96
Well this can be used on bellsing 6 to lower bass and mids to treble nearby level if we are able to find something while doing hit and trial.
Dont go with the numbering(like 66 etc) those are reference number in research paper.
See the formula below
RW = resistance DCR of woofer
Rt = resistance DCR of tweeter
Resistor is on positive leg
Inductor on negative leg
Try to keep capacitance of crossover, RW and Rt as small as you can
So that you can find the inductive value.
I took the zobelled RAB and was trying to use an ED29689 as tweeter with 470nF capacitor
Which give RW = 22 ohms
Rt = 3.65 ohms
C = 0.47uF
I will try doing it.
I have to make DTEC impedance be equal to TWFK in bellsing6
So I get overall 8ohm impedance flat.
Then I am thinking of adding series resistor of 20ohms.
That will make sense
