Shilohsjustice
- Nov 28, 2014
Don't do that. You'll damage the lacquer layer and you won't get better polish than lacquer.
Thank you for the heads up!!
To all who has problems with their colloids.
I read that the melting temperature is around 94 degrees and processing temperature is around 47 degrees celsius.
As i understand it, we need to melt it first at 94 degrees C and we don't want to heat it too much either or it will loose its transparency, then cool down to around 47 degrees, then pour in to make a mold.
Does anyone have a clue what the blue light tube is for in the professional uv light units sold by the big manufacturers?
http://dentamid.dreve.de/media/uploads/anleitungen/Polylux_PT_Anleitung_GB.PDF
This unit has 2 UVA bulbs and one blue light bulb?
Its the same from the other manufacturers.
I have tried to insert a regular Knwoles damper into a 1.5mm ID tube and it was so difficult I couldn't make it pass the entrance of the tube...
At first I couldn't even insert it so I had to enlarge the opening of the tube using a heated pair of tweezers (heated with a lighter for a few second then inserted into the tube opening to enlarge it). After I managed to make the hole slightly bigger I managed to insert the damper but couldn't make it slide any further...
Now I know that the dampers have ~2mm diameter and the tube I am trying to insert it in have a 1.5mm ID but I am quite sure I have seen it done on CIEMS before.
I saw for example here some kind of workaround using a small part 2mm ID tube just for the damper and attach it to the 1.5mm ID tube.
I would like to know if there is a technique to do it? or some kind of special tool being used?
As far as I know multiple bores CIEMS use a 1.5mm ID tubing (right?) and sometimes one of this bore may have a bigger 2mm ID tube so how do they manage to insert the dampers into those 1.5mm ID tubes?
I am very confused now. Check the picture which is from the Egger EL 2 manual (wrong caption on the picture). If you also check their Egger EL3 which is for curing Lacquers, they use UVA.
The Egger EL2 does have a switch for the two levels. Obviously the UV Resin needs both lights? Is that the problem so many has? Not curing correctly because of missing blue lights?
Edit: Manual to Egger EL2
http://egger-labor.de/enplace/1101/pdf/en/51210a.pdf
