hifimckinney
- Jan 12, 2015
Any proud owner in or around Dallas area?
I took delivery of mine (level 3) yesterday and it is warming up/burning in as I am typing this....
I just wanted to take the time to second Joeybgood's experience dealing with Tim at Kitsune, I too took a punt on the new unreviewed Holo Spring 3 dac and to say that I am over the moon in this early stage is an understatement! There will be more to follow.
Any in the San Francisco area?
the newest dac in the works is the "May" dac and will be priced in the range of 3-4K and be even higher spec than the Spring Dac.
Hi bimmer100,
is there a release date for the "May" DAC? Or is it in the very early stages of design?
I was wondering if any owners have sucessfully played dsd via jriver with the asio driver?
It is not working for me, wasapi and kernel streaming dsd playback works but only via DOP not native.
Otherwise the dac is sounding quite nice in my system.
Hi Bimmer and Rocky,
I have a kind friend who loaned me his unit for a demo
Its running latest firmware and driver, I'm using latest Jriver on windows server r2.
Now I understand that the firmware and software is still under development.
I have a dual boot Snakeoil / Windows Server setup, will try Snakeoil and report back with the results.
Cheers lads
@bimmer100 I did not want to quote your entire post, but that was very helpful. May I suggest putting the information about the tuning and the collaboration with Jeff prominently on your website? I am very interested in this DAC and information like that helps a lot since there are far too many people in this field that make claims about everything under sun making improvements about the sound.
Knowing that the design engineer would have opted for the upgrades, if not for cost considerations, heavily tilts my opinion on the matter. Of course hearing it will be the ultimate test.
When you make demo units available for folks on this thread, I would ask to be amongst them. I'm currently looking for an excellent DAC to complete my signal chain. It'll be paired as follows:
FLAC from PC--> Schiit Wyrd--> Spring --> Cavalli Liquid Gold--> Focal Utopia
I look forward to more impressions and reviews and thank you for the detailed response.
Oh Dear. Thank you. I actually am a nice person in person but then... I'm going to assume the mid-range is all you hope it could be. Tone? It's late so I was going to be a bit silly. Instead, I could have bought a nice safe Auralic system for all the money I've spent, but no fun and no learning. Yggy seemed a safe bet as well. And perhaps I needed more research but Yggy did not seem to be keen on over sampling adventures. The Spring DAC has that nice Oversample button. You can drop-kick your 44k stuff to 384K or DSD. Or have pure NOS. So NOS does have the most beautiful Tone. It is not a syrupy mess. It is smooth, not a hint of anything harsh but has all this soundstage with immense detail stretching out to the horizon. Up sampling does change the Tone and soundstage. Things get a bit sharper. The sound may be tightened up a bit. Soundstage is a bit more Normal. Actually closer to what I get with the Master 11. Of course the Spring DAC is up on the railing with me looking down at poor Master 11 below. (I can't believe myself). I'm using my HD800 set with a Norne Draug II cable. Caution! I believe that cable is Magic. And I might be cheating by having my MacBook USB plug into the Singxer SU-1 then into the Spring HoloDac (let's play Scrabble with the only letters being HoloAudioSpringDac). I have only briefly tried the Spring DAC's USB, plain vanilla, no Intona, Regen, Jittebug yet. The SpringDac USB sounded pretty damn fine on it's own. I'm sure that's proof of something for someone right there. It may be a bit louder than the SU-1 unit. I had to turn down my amp a bit. Teensy bit bolder sound? The Intona has made an immediate, audible improvement to everything I have tried it with. It could be a real treat with the Holo Spring DAC. Tomorrow after Svengoolie.
One more thing about tone. I was convinced that Balanced sounded better than Single Ended. So I bought a Single Ended microZOTL OTL Tube amp. Get it all over in one fell swoop. I needed to find out. I ahem, really do put my money where my mouth is. And I found out Single ended Can sound just as big and wide and buzzword-able and as enjoyable as Balanced. The Holo Audio Spring DAC is just as nice Single Ended as it is running Balanced.
