Microsoft finally has a build of Win10 that includes Native Class 2 USB Audio support - i.e. "kernel level" support for USB audio devices. That means you can skip the device driver.
Computer Audiophile has a nice write up on it HERE.
I installed the Windows "Creators Update". (took 40 minutes!) and have begun experimenting with it.
In the image below, you can see the new output format is labeled "Kernel Streaming".
Here's some of the higher bit-rate formats that I've been able to play so far:
USB Audio Class 2 streams DSD in the familiar "DSD over PCM" (DoP).
- 24/192Khz PCM
- 24/384Khz PCM
- DSD64 @ 2.82Mhz
- DSD128 @ 5.64Mhz "Double Rate"
- DSD256 @ 11.2Mhz "Quad Rate"
