thompsontechs
- Feb 7, 2017
I just ordered both Spring Kitsune and the SU-1. Now comes the problem with the wife.... :O
http://www.head-fi.org/newsearch?search=ddc
Indeed DDC is the correct name for these USB components, AKA "USB interface". I had however mistook it for Domain Digital Converter instead of Digital to Digital Converter and called it a USB component instead of interface. The terminology for these relatively new devices are somewhat perplexing to say the least, but at least some universal terms are surfacing for these, LOL.
I have the Singxer SU-1 DDC shown above. It was recommended to improve the sound being fed to the Holo Audio Spring DAC, to which I had also personally confirmed from testing. I got it in anticipation for that DAC, but in the meantime it's doing wonders for both of my current DAC's ('Mimby' and Gustard X12, which it's able to connect to both simultaneously via AES/EBU which is a 3-pin XLR cable, and RCA coax to the other DAC. On both DAC's (as well as the Holo which I previously tested it with / without), I'm noticing an unmistakable improvement in all aspects of fidelity - everything from dynamics to layering, imaging, and especially overall realism. The drums hit harder, things sound more real, instruments are placed better and I turn my head more often to check if what I heard was real-life or not. I am using this in conjuction with the Wyrd from Schiit Audio (PC --> Wyrd --> SU-1 --> DAC). I have tested each the Wyrd and SU-1 DDC's alone and together and have concluded after extensive testing that without any doubt whatsoever the pairing of these two DDC's together are legendary and give unmistakeable improvements to the sound, with absolutely nothing over or under-done. Yup, this is the DDC setup I'm standing by and I've read from multiple members it gives even better performance to a DAC when used with the I2S connection, which is actually via HDMI cable.
In regards to the Hugo 2, while that's great it does accept USB input via micro-USB cable, I personally would need to do a little more research to see whether a DDC "USB interface" would further benefit this connection or not, because the vast majority of the time, everybody who has tried a DDC into any DAC reports further improvements... and while I understand the basic functions of taking a USB binary stream and converting it into other digital connection options I'm no expert on how these work; however I do also know it also has something to do with digital "re-clocking", and has other ways of "cleaning up" the signal from a USB, which is necessary because the USB board of the majority of computers are not implemented in a way this is able to give optimal performance if connected directly to an audiophile rig.
PS- the Singxer SU-1 outputs are not compatible with the Hugo 2 AFAIK, however the budget-friendly Wyrd would work.
What is the basis of your claim that "cleaning up" is necessary because USB boards of majority of computers are not implimented to give optimal performance? Do you have technical information to support this claim? I feed my run-of-the-mill Dell desktop PC directly to my Bimby with wonderful results.
BTW, Schiit markets Wyrd to clean up "strange" noises and prevent "drop out". They expressly disavow any claim of sonic improvement:
"Yes. Some listeners say Wyrd improves the sound of their system. We won't make any such claim to sonic nirvana—sorry, creating expectation bias and neuro-lingustic programming ain't something that we do. Sonic improvements are for you to decide. The rest of it—color printing and data stability—that’s like saying charging your iPhone off Wyrd makes the battery last longer. Have fun with that one"
Good one Pct.
First tube rings, then USB boards needs cleaning up. If you're that 'audiophiled' then get yourself a dedicated source instead of a PC. As for me, my NASA computer with the state of the art USB board is good enough.
I love Schitt statement - they want to dispel any expectation bias.
i am intersting in this Holo Audio Spring R2R, i wonder where we can get best price for the basic version ? And how much it cost for upgrade the Silver O-Type transformer ?
Level 1:
https://kitsunehifi.com/product/springdacbase/
Level 2:
https://kitsunehifi.com/product/springdacred/
Level 3:
https://kitsunehifi.com/product/springdacgreen/
Thank you !
BTW, those Holo DAC made from China , right ?
Yes they are, but you get full 3 years worth of transferable warranty through kitsune.
Some Holo Audio products are exclusive to Kitsune - such as the KTE (Kitsune Tuned Edition) of the Spring DAC.
Interested in this DAC. Do they ship outside Canada and US? In the shipping options, New Zealand is not listed as an option. And how do we choose the 230v version? Cheers.
