For the sake of completness of comparing Ferrum and Bliss after another few days of burn in and intense listening I can add some objective and subjective differences :
1. Ferrum has upper mids / lower treble filled in, it is a bit sharper and more full in this region (where snap of snare is, lower pitched cymbals etc.), and Bliss has a dip in this region.
2. Ferrum in general sounds sharper and faster, but it makes it also a bit more clinical and less relaxed.
3. This makes the Bliss sound wider and more "stereo", while imaging on Ferrum is more in front (you could say more correct, having a dip in around 2k region is a well known psychoacoustic trick to make the stage seem wider)
4. In general Bliss staging is a lot wider and more to the sides ... which can make it less coherent or even borderline blurry in comparison, Ferrum stays sharp in front with perfect imaging, but significantly smaller stage and less "organic" sound.
5. That also makes bliss lose some of the small details in and around 2k region, like distant pianos are less discernible in comparison with Ferrum, Ferrum pulls a lot more detail to the foreground especially in midrange and treble.
6. I think Ferrum fills in this 2k region on purpose bc Susvara (and other HiFiMans) have a dip in this region and they are going for "all the facts" presentation, but without fatigue etc. Ferrum is a fairly relaxed sounding amp, but Bliss in comparison is another level of sounding relaxed.
So if you're after ultimate details and clarity, Ferrum is your guy. If you're after more immersive sound with bigger, wider stage and relaxed sound ... but you don't mind losing some details and speed .... Bliss is your guy.
The funny thing is, that both Ferrum and Bliss apparently are tuned for Susvara, but both are really different, and while I can see how Ferrum fills in Susvaras deficiencies making it even more "true to life" and maximises resolution, Bliss goes kinda the other way and makes Susvara sound even softer, even bigger ... bass for me is more less in the same league on both ...
... and the funny thing about it is that those qualities make Bliss the perfect amp for TC by accident it seems
