esanthosh
- Dec 21, 2009
Do you need to use all those steps? Here's what I did (at least this is what I think the Instructions said and it worked)
I have always used "Safely Remove" for all external devices for as long as I can remember. So, no changes on that front.
From beginning to end, I did exactly as follows:
- With the Studio-V already off, I pushed the RESET button down for a second or two, then released.
- I then held the MIDDLE key for 2-3 seconds, and of course, the player shouldn't turn on, because of step 1.I then released the MIDDLE key.
- I waited ~15 seconds.
- After ~15 seconds, I held the UP key, and all the while, I connected the USB cable to my Studio-V.
- Removed the microSD card
- Kept the Center + Up key pressed while connecting the USB cable to the Laptop. RoCoo is recognized as "USB Input Device" by Windows 7.
- Ran the firmware updater with "Format" option enabled.
