goodvibes
- Dec 28, 2009
correct. I tend to use large files (so not as many) and subfolders so not a biggie for me.
I finally got around to trying the latest FW on my Anv 3.
http://www.hisoundaudio.com/Uploadfiles/20131117175558560.rar
I like it. I think it's the best sounding of the bunch. You lose the hold to scroll function but other than that, I don't see any issues. Installed the way I like it best with the 2011 FW, I think it maintains all the detail with a bit more color and less etch. The installer supplied only works with XP (Ithink) so you'll have to copy the old installer into the folder for W7. For best sounding result, start the normal install procedure. When recognized after opening the updater, do a quick (not slow) format at 4096 allocation size before starting the updater. Don't check any of the updater boxes. (fromat and erase) Once ready and started, disable BTN sound in the settings menu. The difference isn't huge from this same type of previous install but enough for me to forget about the scrolling.
Silly question but does anyone have a link to the old installer that works for win 7? Gonna try updating the firmware!
Sent from my C6603 using Tapatalk
Hmm so you like the sound better? I never stuck with it long enough to really notice. I just couldn't stand how buggy the UI became after that. Especially having to click each time to scroll down....
Yep, scan time is longer but I don't find the UI any different other than no scroll as mentioned. Library, clicks times and sensitivity seem the same. This isn't going to be better for everyone so having the old standby FW on hand is not a bad idea. Easy enough to revert back with the same instructions. The sig comments may vary by how the old FW was installed. This is my fav sonic setup but 122311 is also VG and does have the best load times and scroll. Use whatever rings your bell.If I was all about load times and great UIs over sound, this wouldn't be the player I'd choose anyway.
about 1/3rd longer
