lee730
- Jan 9, 2011
Well I don't have issues using Media Monkey to sync my music. All my folders show up in the proper area and my music works fine. I suggest you try and delete the "system" folder from the internal memory and see if that is your problem. When you load a bunch of new tracks you need to do this each time so that the unit will properly re-index your files. This may help them show up properly. I hope that helps.
I also have a guide on how to clean your tags via mp3tag. I'll post that for you below.
http://www.head-fi.org/a/mp3tag-setup-guide
Yeah, I don't get it either. I like using JRiver's player, but maybe I'm better off dragging music? That would really mess up track labels, though
Sent from my DROID RAZR using Tapatalk 2
