Mackenzie
- Sep 24, 2015
This is indeed the route I'm going, more or less. A modest DAC/amp and several headphones to try out, so you can find what you really want in a headphone. Good luck with your search!
Yess, there is much to learn and try out so it will have to be a timely process. Thank you and for your help getting me started on my sonic journey!
By the way, I'm leaning toward this for the 5.1 setup:
http://www.bestbuy.ca/en-CA/product/logitech-logitech-5-1-computer-speakers-system-z906-980-000467/10179850.aspx?path=be43d18f8c3e11834e3dc1263acdf259en02
Do you think that is an alright way to go or would you recommend something a little more basic? Better? Hmm. I'm not sure I understand the difference between computer speakers and well.. regular speakers? Can't both be adapted to fit in any environment with the right cables and adapters? Is the 'computer' label basically flagging that it's worse than standard?
