ThanatosVI
However this is a rather complex topic, since the passlabs combo sounds superb while not offering much power.WA33 is spec'd at 10W per channel at 32 Ohms. So power to the Susvara (60 Ohms impedance) approx. a shy over 5.3 Watts ! For Susvara this is quite low !
Hifiman EF-1000 provides 20 Watts at 35 Ohms i.e. approx. 11.6 Watts to the Susvara, i.e more than double the WA33. As Hifiman updated the EF-1000 to get the best out of their current Planers in particular the Susvara, this should be the sweet spot for power to the Susvara !.
The Trafomatic Primavera can deliver 9 Watts into 50 Ohms i.e. approx. 7.5 Watts to the Susvara.
Ok it's not just about pure power (voltage swings and current are the important parameters for such headphones like the Susvara) but there is a pattern from reviews and people using Speaker Amps that the more power (up to a point) the better the sound from the Susvara.
I haven't read a review yet that too much power (within the max power the Susvara is spec'd for of 25 Watts) diminishes the sound quality of the Susvara's being fed from a quality Amp.
25w into 8 ohm could be as low as ~3.5w into Susvara load (60 ohm)
