mtoc
- Oct 22, 2015
attacking Tyll on prupose will surely gets his attention, these guys are pretty smart
edit: get
edit: get
I seen his name mentioned, however I did not see anyone attack him, unless I missed something !attacking Tyll on prupose will surely gets his attention, these guys are pretty smart
edit: get
It sounds like he characterizes it as somewhat an HEK jr. Also, he finds the response on the cooler side, and like people have been mentioning of the recessed mids, his EQ boosts the upper mids. He also boosted a bit of a low-end as well.
Yes, very interesting indeed.
Good to see that folks here are hearing what the experts hear and measure.
The treble seems a little rolled off at higher frequencies but very clean and neutral.
Astonishing.
The shelf-like dip that I was talking about appears to be there, but I cant see that it is in any way excessive....interesting.
I have doubt that Sundara will sound like HD800(S). I also have doubts that it will sound as spacious as HEX or HEK although Tyll does say it sounds spacious. I thought LCDs(don't know about the X series) are characterized as on the warm side with lower treble recess. Utopia does have bit of a presence in the upper-mids and higher. I thought Clear and HEK had more of a presence in the mid treble(with Clear with more upper-mid presence), more of an abrupt rise at about 9k(with HEK having more energy of the two), and below wasn't as prominant as something like HD800 or Utopia.I guess you heard forward sounding cans like utopia and lcds. I also heard forward sounding cans like clear, aeon flow open. So it might be the case that both of us felt mids and highs are recessed compare to them. Just my 2 cents.
If you go from mid recessed to mid raised, the difference you hear would be very noticeable, and the immediate impression could be more exaggerated. Or in another perspective mid raised to not as much mids, but in the perspective is one mid raised or one mid lowered? Same goes for dark and bright.
To my ears, female or male vocals sound veil - in comparison
to the more expensive units.
Mids and even highs are recessed, very much like HE1000v2, - not upfront.
The midrange region lacks detail .
This detail helps create a well defined and clear picture of the music.
Switching to HE-6 gives you fireworks of detail and very precise picture of musicians.
Stay updated on Audio-Technica at their sponsor profile on Head-Fi.
I hope Sundara has more bass than HE560. It's sounding like it's about the same level or hopefully not less. This means it's probably not that close to HE500. At least it doesn't take as much to drive as the HE560, which is more than twice.
Very curious to know what kind of rig you’re running. As an owner of an HE1000 v2, HE-6 and Susvara, I find your impressions to be all over the place and definitely different from my experience. If you tell me your gear maybe it would shed light on the whole affair, but for now I can’t help but scratch my head on some of your impressions and why you’ve stirred a reaction with other members aha!
The HE6 should always sound meatier, unless inadequately driven, compared to Susvara. Sounds like your high end headphones are being seriously under-driven
It seems like you have The Editon X and HE 1000v2, could you please leave a few words and compare them to the Sundara.Very intersting to hear your opinion....so I am not the only one
I did feel that I preferred its sonics to both Edition X - which is way too dark for my taste, and HE1000v2, altough - in terms of low frequency response is without
equal - but sounds less balanced at higher octaves (just my opinion).
Sundara still sounds ok from a less-than-stellar-company electronics.
HE1000v2 really needs an amp in its own class to really shine.
Sundara still has that shelf-like low pass response - very much like the Audezes, which gets it to the darker side of things. Interesting to see some measurements.
I don't hear this with the HE1000v2's.
Against the Edition X, Sundara has a little more output, a little more energy on top, but just as smooth and laidback.
Any ideas?
