In case it hasn’t been brought up yet, Arctic Cables now sells laser cut metal replacement grills for these. They look really nice, haven’t had a chance to put them on my pair yet but they’re very nicely made
HifiMan HE6 V2 Adorama
- Thread starter Kevintj604
wolfstar76
Just ordered one pair, thanks for the info.In case it hasn’t been brought up yet, Arctic Cables now sells laser cut metal replacement grills for these. They look really nice, haven’t had a chance to put them on my pair yet but they’re very nicely made
Andrew_WOT
- Jan 18, 2004
By looking at the close ups it has protective fabric mesh installed, is that how they got shipped or you need to glue mesh from stock grill?In case it hasn’t been brought up yet, Arctic Cables now sells laser cut metal replacement grills for these. They look really nice, haven’t had a chance to put them on my pair yet but they’re very nicely made
https://www.arcticcables.com/ac-store/AC-Hifiman-Grill-Mod-p461014835
- Mar 20, 2013
Just took a look, very cool grills! Not sure whether this is possible, but larger openings would also look great
Stay updated on iFi audio at their sponsor profile on Head-Fi.
Mine didn’t have any mesh on them.By looking at the close ups it has protective fabric mesh installed, is that how they got shipped or you need to glue mesh from stock grill?
Here’s how they look installed
gimmeheadroom
Looks grate! Pun intended
I have 2 pair coming from member @BowWazoo in the next few days. I'm looking forward to hearing the difference from stock, and also his pics look great.
Andrew_WOT
- Jan 18, 2004
Yes, they do not come preinstalled, you need to reglue or somehow attach them to new ones if you want additional protection for exposed drivers (dust, metal particles attracted by magnets, etc.)
From the instruction on their web page
How to install:
1. Use a flat tool to remove the outer ring and remove the stock grills.
2. Install the new grill with or without the thin filter from the stock grill and insert the outer ring.
BTW, how do you find comfort with this headband, I was trying to use exactly the same on my pair and the weight was just unbearable, I didn't have that extra cushion like yours have, does it really help much?
You were using a ZMF headband? I find this setup extremely comfortable. The strap does a nice job of distributing weight. If you had issues though, you might try the newer ZMF crescent strap. Different padding on the underside of the headband itself, is certainly an upgrade over the regular ones.Yes, they do not come preinstalled, you need to reglue or somehow attach them to new ones if you want additional protection for exposed drivers (dust, metal particles attracted by magnets, etc.)
Fwiw I did find that these grilles are a little bit smaller than the opening they sit in. Not sure it’s an issue but they have enough play to slide up and down about a millimeter or two.
Andrew_WOT
- Jan 18, 2004
Yes, this exact model. I wish I could get newer one which supposed to be more lightweight, but unfortunately ZMF only provides them as a repair option for their phones owners. Tried to adjust for a few days then just gave up and went back to stock one, and that was a great relief. Real bummer as really liked how it looked.You were using a ZMF headband? I find this setup extremely comfortable. The strap does a nice job of distributing weight. If you had issues though, you might try the newer ZMF crescent strap. Different padding on the underside of the headband itself, is certainly an upgrade over the regular ones.
That's kinda shocking to me. I couldn't wear these with the stock headband for more than half an hour or so before I got a massive hotspot right on top of my head. The ZMF one (and I think this might be ZMF Headband Version 1.0) is perfect for me, but I always find ZMF cans comfy. Plus I'm an unabashed fanboy. You might get a suede strap and try it out... I have suede straps on my HE6 and my Auteurs. A bit more cushiony.Yes, this exact model. I wish I could get newer one which supposed to be more lightweight, but unfortunately ZMF only provides them as a repair option for their phones owners. Tried to adjust for a few days then just gave up and went back to stock one, and that was a great relief. Real bummer as really liked how it looked.
Andrew_WOT
- Jan 18, 2004
I was just getting headache from extra weight pressure, still using stock headband with this padding, very comfortable and lightweight.
dstarr3
The Shane-signal seems to not be working, so I'll mention the Dekoni nuggets on his behalf
Love mine! Night and day difference.The Shane-signal seems to not be working, so I'll mention the Dekoni nuggets on his behalf
Flak
- Feb 25, 2013
How would these be for gaming (FPS), compared to something like the R70x (which I also don't currently own)?... Or just save up for some version of the HD800?
Chain: PC > Monolith USB > Bifrost 2 > Jotunheim 2 > Hart Balanced
Headphones: HD58x | K7xx | Sundara | A900x | iBasso SR2 | Nighthawk | Clear Pro
omniweltall
- Nov 13, 2016
I think this would be a great FPS can, because the speed, separation and clarity is very good. And your chain (Bifrost 2 => Jot 2) is a good match as well with the HE6se v2.How would these be for gaming (FPS), compared to something like the R70x (which I also don't currently own)?... Or just save up for some version of the HD800?
