I'm talking about the attenuation ring
HifiMan HE6 V2 Adorama
- Thread starter Kevintj604
Have you tried EQ’ing them at all? I don’t find them to be sibilant at all (even without EQ). Could be your source, could be your ears vs my ears, and mostly, it’s the recording.Just finished grill mod on the HE6se V2.
Bass and sub-bass are execllent.
Mids are nice.
However, treble is sibilant and fatiguing.
Does anyone have any advice how to tame the treble, EQ or otherwise? (I generally enjoy mids and highs)
I find any decent headphone gets sibilant when the recording is sibilant. A headphone that portrays that correctly is a headphone worth keeping.
I also find that any headphone that EQs well, has a pleasurable initial experience, and can change with your source and amp is also worth keeping.
The he-6se is all of the above for me.
hottyson
- Oct 8, 2003
I just got done playing the HifiMan HE6se V2 on a whole bunch of amps in my Questyle CMA Twelve writeup.
Click on it to read the details or you can just read my amp summary for the HE6se V2:
1st place - Questyle CMA Twelve
2nd place - Rebel Audio RebelAmp
3rd place - Schiit Jotunheim 2
4th place - Schiit Jotunheim 1 (Discontinued, readily available used)
I did not mention in the writeup that the treble was a tiny bit hot on the HifiMan HE6se V2 when paired with the Questyle CMA Twelve because it was very slight and I could listen past it, and could likely EQ it away if I really wanted to. However, many of the other amps that did not make the cut were hot in the treble region. This ran through my brain as some of you reported hearing "sibilance" or a hot treble response. I think that some of you might be experiencing results of under-amping the headphones with weak amplifiers, or just have an amplifier that does not play well with the HifiMan HE6se V2. Perhaps try the HifiMan HE6se V2 on other amplifiers to hear if the problem goes away.
can you describe he6se v2 and Schiit Jotunheim 1 how it soundsI just got done playing the HifiMan HE6se V2 on a whole bunch of amps in my Questyle CMA Twelve writeup.
I tried mine with with a jot1 and 2 and I can tell you it didn't do the he6 justice, it got it loud enough but the highs where harsh and the bass was anemic
bagwell359
There are lots of ways:Just finished grill mod on the HE6se V2.
Mids are nice.
Fuzzor mod
Equipment changes - what do you have ? these cans reveal up stream crap.
Pads - stock is awful
Cable - stock is awful
EQ - not just just FR but where the ringing is at. Parametric 6 band minimum. Schiit eq is a toy.
I've written a lot in the he-500 and he-6 and 6se threads - search there for details.
Haven't used attenuation devices on he-6(se). Hard to imagine they would be a net positive. Fine for rubbish like the MD Mahogany, not a thoroughbred
tnx for replyI tried mine with with a jot1 and 2 and I can tell you it didn't do the he6 justice, it got it loud enough but the highs where harsh and the bass was anemic
i have jot1 at home and i am waiting for he6se v2, i will have to use jot 1 for a while until i save for Flux FA10.
What are the basses on jot 1?
Try the singxer fa1 if you can, you would greatly benefit ffrom it
I think flux fa10 is betterTry the singxer fa1 if you can, you would greatly benefit ffrom it
Wait, what are we talking about here? The earpad mounting rings or the attenuation rings which is in addition to the earpad mounting rings.
I guess both, unless you can use the attenuation ring with the HE pads or HE replacement pads?
