gimmeheadroom
There's no denying the Audeze "house sound" has an egregious 4kHz dip that's controversial to say the least.
Really? I deny it. But I agree your comment is controversial. So maybe I misunderstood you
It's either a 4kHz dip, or a 1.5kHz bass shelf and a 8kHz treble shelf!Really? I deny it. But I agree your comment is controversial. So maybe I misunderstood you
I understand that for sure. Had that issue for years. Took me years to get used to non suspended headbands.I guess my head shape is a bit weird. Seriously I can't use any non-suspension band headphone. Even ones which have large consensus about being the most comfortable headphone ever (like the HD800).
I just put Audeze LCD-X 2021 and LCD-XC on my ears. Both did sound good without equalization and I enjoyed listening to them. However, when I engaged the the equalizer the result was much more articulate and enjoyable. I did notice that I could not turn up the volume as much to rock out on either one equalized approximately to to the harman curve. At normal listening level I would much rather equalize if the option is available.---snip---
And on Audeze, LCD-X 2021 sounds perfect to my ears without any equalizer.
Was the XC the 2021 as well?I just put Audeze LCD-X 2021 and LCD-XC on my ears. Both did sound good without equalization and I enjoyed listening to them. However, when I engaged the the equalizer the result was much more articulate and enjoyable. I did notice that I could not turn up the volume as much to rock out on either one equalized approximately to to the harman curve. At normal listening level I would much rather equalize if the option is available.
Yes, I am not familiar with the sound of pre 2021 Audeze headphones. My 2021 Audeze LCD-XC sounds good for a closed headphone. However, if my listening situation does not require a closed headphone, I am definitely going to grab something else open over using these LCD-XC.Was the XC the 2021 as well?
I've owned no less than *three* pairs of those things and found the midrange honk unbearable, mixed with an intense 8-10kHz. This was before I got a Lokius, but I was wondering if that was addressed at all.
Super! Did the yokes require any modifications?Just want to share my latest mod: a crossover between ZMF and HE6se
ZMF headband for comfort, ZMF universal perforated pads for neutral tuning and comfort, and of course HE6-se driver that drives the music out of the can
I want this so bad LOLJust want to share my latest mod: a crossover between ZMF and HE6se
These pads look massive, what is the diameter of ear opening, is it round or oval?Just want to share my latest mod: a crossover between ZMF and HE6se
That is definately a stuck driver. I was measuring my HE6se V2 and diaphgram got stuck to the magnet. Same channel, maybe a minute between the measurements. That midrange hump can't be a coincidence. Also I visually checked that the driver is indeed stuck now.This discussion is making me wonder if the set HE6se V2 that Crin measured has a stuck driver because the bass is significantly reduced on the one channel.
