tmb821
I put on a set of hm5 angled pads I had laying around. I much prefer the leather to the velour. And my ears no longer touch the pads anywhere. Win for me!
Never even knew that could be done. Really classes up the look! Might have to try it out as the standard headband does have a bit of a dead weight/crown pressure feel and the clamp isn't all that good. NX4DSD is a nice combo with these cans too!I swapped out the stock headband of my 4xx for an HE560 headband and it's great. Improved comfort and fit which I feel helps created a better seal on my head and thus improved sound. So my answer to the post title is 'Yes, a headband can improve sound.
Someone had posted this mod a couple of weeks ago and I thought i'd give it a try. I ordered the HiFiMan Headband for V560V2 from Adorama for $40. It's an easy install. You have to stretch the yokes a bit, but it's not difficult. I have the 4xx with the 2.5mm cable connects. The size of the hex screws that hold the headphones to the yolk are 1/16. Make sure you have the right size hex tool the screws are easy to strip.
Not only does the headband look better it's way more comfortable. The 4xx don't feel as heavy on my head. The clamp is tighter than the stock headband, but not bad. I expect it'll loosen up a bit over time. I wore the 4xx560 for about 90 minutes straight today with no fatigue or hotspots on my head. I recommend this upgrade!
Welp, at least you got a good DAC/Amp(kinda).Late comer, just join HIFIMAN fan club with my very first planar headphone. Sound fun and playful in from initial listening. Still at early stage of auditioning.
Sorry to hear your disappointment, have you tried from headphone amp ? As compared to my HD650, HE4XX is more musical and lively. HD650 more detailed, neutral, thus it may sound dull to some.Sorry Guys, I don't want to dampen your fun with the can here. But if you want to know what a really bad headphone sounds like, buy it.
Sounds like you had a defective set. As has been said many times before Hifiman QC is suspect.I don't rule out that mine was not 100% when it was delivered. It's possible. But the sound was horrible.
I had it on the ADI and the iFi micro iDSD like you. But all of that didn't work. Dull, dull, impossible sound!
It really is, unfortunately you can't simply change the headband to the new hifimansShoulda tried the HE-400, original. Bliss.
Isn't that the Deva headband?Headband looks interesting..
