I agree, impact, accuracy and imaging are improved by the absorbing foam ring. Covering the frame holding the magnets resulted in a further increase of accuracy,
but of a lower magnitude than the foam ring. Keep in mind that the sound waves are reflected from the outer ear to the driver, from there back to the outer ear and so on. Even the magnet bars are reflective, but I won't risk to cover them all. After all it's 26 bars, and one small mistake may result in a damage of the membrane. .....
....it's a bit risky in that the velvet could lose some fibres which could get into the magnet system.
I agree about the dangers of those fibers.
We don't want those fibers to dislodge and fall into the driver membrane area,
which looks to have an oily surface on earlier models.
So far, I believe the tape mod material, suggested by Currawong looks to be the safest material.
Anyways, I've finally decided to do the Tape mod..(!)
I tried everything else (almost),
and this area you guys covered finally convinced me to address.
So I agree the vertical frame is an area to now cover.
That leads me to an interesting observation. I believe these areas was also addressed by hifiman in the V2.
As the new V2 drivers have a dry, pitted grey surface,
While the older drivers have the extra layer of glossy/smooth black on top.
This is an example of the newer drivers being made.
I believe they stopped using the smooth black layer on top, with the dry pitted grey , to disperse the reflective surfaces, and,
(more probable), to reduce weight that came with the glossy black layer.
It probably was cosmetic in nature to begin with.
Anyways,
So my concern is to have a material which will NOT fall off and into the driver membrane.
Also,
My observation with different foam densities resulted that the more denser foam = A bit more closed in sound.
Probably because it was more reflective according to its density,
And so can add a sense of noticing it.
Yet I have not tried enough foam types by no means.
Another train of thought, is that the V2 may still have an area of space for foam to cover, and can benefit from taping some of its driver surface as well..(!)
