Yes, I compared the P, P-SE and HEK SE on the same chain(s). You need to read my impressions across 2-3 posts on the T+A Solitaire thread.Anyone compare the HE1000SE to Solitaire P on the same chain ?
In short, I wasn't out to find the absolute best, I was only interested in knowing if it was worth the cost of changing my HEK SE to either the Solitaire P or P-SE.
And for me it wasn't worth the cost. And, on reflection, I'd still probably choose the HEK-SE even if starting from scratch. If you combined the strengths of these 3, then you'd probably end up with my perfect headphone. Until then, there is no perfect headphone for me, but the HEK-SE does a grand job in the meantime.
FWIW, I also didn't think the P's fairly subtle differences to the P-SE were worth its higher cost and greater weight (and therefore discomfort). But then again, I wasn't bothered by the P-SE's all-plastic construction whereas some people are bothered by that sort of thing.
EDIT: A reminder that my HEK-SE has an upgraded cable and the Feilian port mod, each of which has boosted its performance. The Solitaires were both stock everything.
