preproman
- Mar 16, 2011
This is what I use to use:
Hey! Glad to see the amp's working out for you. The safest manner of disconnecting the headphones is to turn the amp off in the back, then unplug the XLR M from F. Leave the bindings connected unless you're looking to hook up something else, speakers maybe, another speaker tap adapter, etc.
Hmm, is there any danger of hot plug - i.e. plugging the He-6 in an already powered up amp?
I'm thinking about way to effectively a/b two amps. A/b 2 dacs is pretty easy; my amp got an input select switch; and both dacs output @ 2v so there're already volume matched.
However 1 dac -> 2 (speaker) amps are quite problematic. I'm thinking about making 2x 4 pin XLR male -> Banana, then plug it in each amps. Then maybe build a XLR switch box. I'm worried about the safety however.They'll be volume matched so it's not the full power of the amp into the He-6.
Is there any danger of plugging the He-6 into an "already-powered-up" integrated amp?
You could get by without an adapter with 125x2. Just be careful with the volume control. I'm using a 150x2 integrated, not because I needed that much power. I got that amp to use solely as a speaker amp. It just so happens that it's the second best amp I've heard with them. But it also has an outstanding preamp, giving me a range all the way up to 11:00 on the volume knob before the sound is deafening.
Thank you Wink.
I guess I will order this amp and see how it goes. If we ca get some tubey goddness on the cheap, why not!
