Wasn't there a deal were the EF5/HE-6 combo was sold? It was so long ago but I didn't go for it because I had a low powered SS HP amp custom made for it and I also have a 10 wpc tube amp. Well the HE-6 killed the low powered SS HP amp (the opamps) and the 10 wpc tube amp is inadequate.
Yeah, but don't I also remember that the EF5 was virtually loathed entirely with HE-6? It was meant more for the power of HE-5 I thought, and HE-6 kind of strains it? I thought that was the point of the EF-6, though I also heard at least early on EF-6 had problems and stopped paying attention after that. The word "unstable" appeared in more than one thread
Used quality speaker amps are not cheap, specially the known brands like Threshold, Pass, Krell, etc...
There's lots of "quality" speaker amps that rival the "exotic" headphone amps that are relatively cheap in comparison that are floating around out there. Exotic speaker amps like Pass and Krell are another thing entirely...
I think he's mixing up speaker amps with non-refurb vintage receivers.
Receivers, integrateds, etc. For $300-800 you can get stuff that would be some crazy $800-$1200 balanced amp in headphone land
That's starting to change of course, but in years past, it was just a matter of scales of economies....more speaker gear out there than headphone gear, and more audiophiles to buy it. Now it's swinging the other way.
If you were referring to me that is, but my point was for $200-300 you can get one of those receivers or otherwise that acts as a pretty good speaker amp, where the really good headphone amps don't start until well above that price, thus HE-6 has a different value proposition than the average headphone since it can use that gear.
Do you think that's what it is? I'm used to more bass?
I don't think so, but it could be.
My last HP was HD650. More bass. I did like its sound too.
It was a bit too "thick" for my perfect sound though, I thought.
As a huge HD650 fan I can say, just from a few days of owning HE-6 so far, HE-6 has substantially more real bass than HD650, but HD650 has excessive midbass (but very little below it.) But it does depend on the recording. Just running through random samples yesterday, something like Portishead that's kind of bass driven comes across fine on HD650, but sounds bass-lean on HE-6. I had to crank the bass tone control up half way. On the other hand, some Mozart divertimenti had killer bass slam. I never realized how strange some of these recordings are. Only HE-6 accentuates some of that strangeness. 4 Generations of Miles had to have some bass tone control added, I couldn't hear the bassist. Yet Coltrane's Blue Train had ample bass presence natively. I think HE-6 controls bass so well that it really reveals recordings where the bass is just recorded too weakly (or too strongly.)
HE-6 isn't for bassheads, but it's also not bass-shy in any way. It has impeccable bass performance (with a driver diaphram that big, how could it not?
) Though I imagine it could be EASILY EQ'd for bassheads.
HD650 isn't for bassheads either, you may be just used to a big midbass hump. Or that EF-5 really IS shortchanging it. You say you have the volume all the way up? That doesn't sound good. The Lyr only got the volume just below half-way for me.
The DAC is the problem you mean?
I suspect the DAC is fine. It's been compared to DAC1 easily enough and measures similarly. Its limitations are more physical than performance related.
I'm curious on how would they repair the cable.
I might as well reterminate it myself. It is oxidized between the Y split and the headphones. It's actually oxidized on one side only.
Keep the old connectors, replace the "defective" copper between them. That could count as repair for warranty purposes!
Really weird that only one side oxidized...
