Compared to the speaker taps the Lyr doesn't do it for me either. But I still don't feel it sounded "underpowered" specifically, it just didn't sound as clean and finesse with detail, which is consistent with the fact that Schiit's pointed out it wasn't built to be ultra clean with detail, it was built for power. I noticed no loss of the low end or overall weight. I did notice loss of some of the detail and texture. It still had more detail and texture than HE-400, but not as much as it's capable of (and I'd guess that it's capable of more than the Marantz & Bifrost are giving it as well.)
I wouldn't buy a Lyr for HE-6, but it sounds good enough that I wouldn't recommend someone
against HE-6 if they intend to power it with a Lyr, specifically if they'll look into something better later. It also gives me hope for Mjolnir & Statement with HE-6
I'm glad you guys talked me into the bigger amp of course, but TECHNICALLY I'd have been none the wiser with the Lyr
I do sometimes do digital attenuation in the squeezebox. The thing that keeps me from doing so regularly is I don't know if it's working in 24 bit space or if it's doing 16->24->16 bit conversions or anything like that muddling up the sound. The other reason is for some reason wherever I set volume with digital attenuation in the Squeezebox, it doesn't always hold there, so the next time I turn it on I could get blasted with 99% volume where I had it set for 75%
Don't get me wrong, I love the SBT, it's far more convenient than mucking with PC sources
Also how do you feel about your BBE EQ. I'd consider the same model you have, but I've always thought BBE had a sort of "close enough for stage work" kind of SQ. Behringer has some "audophile" grade processors...but they have budget op-amps (or worse, DACS) in there, so I'm not hugely tempted to throw an EQ like that into the chain if I don't have specific issues to correct that basic tone control doesn't provide
