preproman
- Mar 16, 2011
10K
10K :eek:
Has anyone tried the HE6 with an Almarro 318B SET amp yet? (18w)
I am thinking of running it off the speaker taps with DIY cables but can i run it direct from the taps?
Thanks!
Impedance mismatch is the problem. The extent to which it plays depends on the amplifier's topology (feedback, no feedback, the output transformer's winding ratio...). Sometimes it's a real issue,at other times it doesn't matter except for the power you'll inevitably lose into a load which is much higher than the 4 or 8 ohm expected by the amp. If you want to play it safe, hook up a coupleof resistors so the amp 'sees' 8 ohm. Lots of details on how to do it if you search.
Antipodes DXe -> Vega -> WA5 K1K port -> HE6
What's your HE6 rig?
Yes, no problems using your Arcam. I think the 6s can handle a bit more power but if the power supply is good in the Arcam, you should like the results.Could the HE-6 be run adequately by the speaker taps of an old Arcam Alpha 8 integrated amplifier?
Talking about power supply, I have a 20 plus year old receiver. Does it make sense to open the unit up and beef up the trans, maybe create an off-board power supply? Can these things be done? If so, what else needs to change in the amp? Thanks.
