HotIce
- Sep 9, 2014
Yes, use a tube amp with a planar. Push a massive amount of voltage into a low impedance headphone. Don't roll tubes, either. Be sure to use the stock, new-production tubes. Then, make sure you complain a lot about bass rolloff and anemic lows, and go straight back to your glorious ATH-M50s.
Such is the way of the master race.
The Lyr 2, according to published material, has a tube VAS, a Mofset output stage (hence drive current does not come from tubes), and it is rated ~5W at ~40 Ohms. Which is plenty of power to drive the HE500.
