Hey, could you share those 3D print files? That would be amazing?The rings don't get bent out of shape? I know using the plain oval pads, my 3d printed rings (I can't imagine the stock rings are more rigid) do bend slightly due to the tension - they flatten out once snapped in properly. The angles need to be stretched far more and i'd think put more pressure on the rings (regardless, I'm too chicken to try)
Hifiman he-400i Impressions and Discussion
- Thread starter MattTCG
- Tags
- hifiman hifiman-he-400i mods
Mr Trev
Here's the post from when I got them
https://www.head-fi.org/threads/hif...-and-discussion.698974/page-884#post-13859257
Here's the actual Thingiverse page
https://www.thingiverse.com/thing:1784520
They work great. Ignore my comments about clicking/noises. That had nothing to do with the rings (the headphones themselves were defective - a replacement fixed everything)
I love my HE-400i with ZMF Ori Pads!
I like it with the stock pads, but with the Ori Pads I'm unable to get the headphones out of my head. Amazing sound!
SONYES
- Nov 28, 2013
Thank you very muchBuy these, $10. http://store.hifiman.com/index.php/earpad-mounting-rings.html
Super simple, pop off stock pads, put aftermarket pads on rings and pop back in place (which can be a little pain but not too difficult)
Merry Christmas to you
I have indeed ORDER HR5 to be THE FAT ONE
And the RINGS from the company site
I would like to say about HIFINAN gave me an outstanding service
And quickly - I got spare parts for the HE400I
Well done HIFIMAN
Fasterball
- Sep 30, 2016
Ori pads are the way to go. I really think they end the debate of which pads are best for the he400is.I love my HE-400i with ZMF Ori Pads!
Brahmsian
Why do they work with the 400i so well? I'm thinking about getting them for my HD560. I used to own the 400i and am familiar with the sound, so I might be able to deduce what the Ori pads will do to the 560 from what they do to the 400i.Ori pads are the way to go. I really think they end the debate of which pads are best for the he400is.
Fasterball
- Sep 30, 2016
They improve the overall comfort considerably, but more importantly they improve the bass of the 400i.Why do they work with the 400i so well? I'm thinking about getting them for my HD560. I used to own the 400i and am familiar with the sound, so I might be able to deduce what the Ori pads will do to the 560 from what they do to the 400i.
I have tried other pads and Ori Pads are the best for HE-400i. This pads improve the lower frequencies and becomes a little warm without getting too far away from your stock sound.
Complementing the information, my Ori Pads have Lambskin finish. I can't ensure the same result with different finishes (velour, protein...)
Cheers
Hi, guys!
For a while I was looking for a new pad for my 400i. Some people recommended the Alpha pads, some says those ar crap. A few people recommended the Ether pads and now the new trend is Ori pads.
I ask this question from Mad_Economis, and he wrote the following:
"I strongly recommend against using non-Hifiman pads on Hifimans
I and several people I know are great fans of Hifiman's work, and so I've measured quite a lot of combinations of pads and Hifiman headphones at this point
And without exception replacing the pads with anything other than Focus makes things worse, pretty much
What the problems are varies by the pads, but you're better off with Hifiman pads
Which is a shame, because Hifiman pads are terrible quality for the price, but the sound really is their strong point
Speaking specifically, I've measured the Alphas on a few Hifimans, and please, do not do it
Given the commonalities of the Ori and Ether pads with the Alphas, Audeze pads, and a few other similar pads I've measured, I would hazard that the same recommendation could be given there
If you're absolutely adamant on not giving Hifiman money, the Brainwavz HM5 Hybrid pads would probably be the least bad of the options I can think of."
So, what do you think? The Ori pads are truely better than the others? How?
Lurk650
Lol don't listen to him. I have BW Sheepskin on mine and i love them. Yes it alters the bass but it's for the better, for my tastesHi, guys!
For a while I was looking for a new pad for my 400i. Some people recommended the Alpha pads, some says those ar ****. A few people recommended the Ether pads and now the new trend is Ori pads.
Just change it if you are not happy of them.
I am happy with my A pads, I could spend 50$ even if I paid the the400i 170$ but I like them a lot.
When I will be not happy anymore of the cans I wil just spend the money on a better pair
Measurement are only good if you want to keep the stock sound, for those that want to change the sound (more bass, less treble) then changing pads is one way of doing this. Only you can say if the Ori, Alpha or any other pad is better than the stock Focus pads. Don't forget comfort since some find the Focus pads not very comfortable and I'd say the Ori and TH-900 sheep skin pads are very comfortable but yes they do change the sound but its up to you if its for the better or not.Hi, guys!
phthora
I didn't think that TH-900 sheepskin changed the sound very much at all. I haven't A/B them due to the PITA of changing the pads, but it seemed a pretty consistent between the Focus and the Dekoni on both the 400i and the 560. In fact, I'm looking at getting some Ori pads for the 400i to get more of a change.
Changing pads is easy and quick using a credit card or similar stiff card. To remove a pad just slide the credit card and gently lift the pad to unhook one tad and slide it over to a second tab and repeat. To mount a pad get two of the tabs in the slots and use the credit card to gently push the tab inward while gently pushing down and the tab should quickly go into place. Takes me about 5-10 seconds to remove and about the same amount of time to install a pad, but its even better when I have my son's HE560 to do comparisons.I didn't think that TH-900 sheepskin changed the sound very much at all. I haven't A/B them due to the PITA of changing the pads, but it seemed a pretty consistent between the Focus and the Dekoni on both the 400i and the 560. In fact, I'm looking at getting some Ori pads for the 400i to get more of a change.
phthora
That, my friend, qualifies as a PITA in my book. Especially, for multiple back-and-forths. Perhaps at the next meet-up I can arrange a less tedious A/B test.
Total: 29 (members: 0, guests: 29)
