thyname
The DP-X1 can put 300 mW into 32 ohm in balanced. At 35 ohm, the 400i will get a bit less than this. To be honest, that is not enough power to fully drive these, balanced or not. My D14, which puts out 800 mW into 32 ohm, comes closer but still falls short. Balanced will improve some things with these, but I think you really need a decent amp to run these well. Otherwise, they going to sounder thinner, more sibilant, and more closed in (at the very least). Something with at least 1 W at 32 ohm should do the trick, IMO.
Such as what?
My brother-in-law is letting me use an Oppo HA-2, so I may try that next week:
https://www.amazon.com/OPPO-HA-2-Portable-Headphone-Amplifier/dp/B00UW0BP48
Everything that I had read before on DP-X1 indicated that had plenty of power to drive the 400i, but I guess I was wrong.
