Just a couple more questions. Would you say the 400i is adequate enough in terms of soundstage and resolution? Also, are there any significant peaks in the frequency response?
As for the 400i's soundstage, whether it is adequate enough really depends on what you're used to and what you're looking for. For example, say you're used to something like the Sennheiser HD800, or any of the AKG 7-series, or any of the other headphones known for a large soundstage. In that case, you may find the soundstage of the 400i to be a bit lacking - it definitely sounds more intimate than those open headphones known for their large soundstages.
However, if you are not coming from those types of headphones, or if you simply don't care and/or want something different, than the 400i's soundstage will probably be fine for you. By no means is the 400i's soundstage small when compared to all headphones - you definitely won't mistake it for a closed headphone.
As for resolution, while some have said that these aren't the most resolving headphones, I feel this is mainly compared to higher-end headphones such as the HE-560. In my opinion, for the price the 400i's are one of the most resolving headphones around. The 400i definitely retrieves more detail than the HD650. And based on my experience demoing other headphones, they are not lacking in detail compared to other headphones such as the Sony MDR-Z7, Final Audio Design Pandora Hope VI, and Audeze EL-8 which are all around or a little bit more than the 400i's cost. To compare the 400i to another planar (besides the EL-8 mentioned above), the Mr. Speakers Mad Dog costs less than the 400i, and as expected given the price difference the Mad Dog definitely retrieves less detail than the 400i.
In fact, I've found the 400i to compare favorably to something like the $1000 Oppo PM-1, although many people seem to agree that the Oppo isn't the most resolving headphone.
As for frequency response, Tyll from Innerfidelity has measured these headphones (link: http://www.innerfidelity.com/images/HiFiMANHE4002014.pdf)
(Don't worry that is says HE400 2014 - this is definitely the 400i, which becomes apparent if you manually go look for this PDF on his website under the headphone datasheet downloads section)
I personally don't see any big frequency response spikes, maybe except for at 7k and 9k, which honestly to me looks like both are part of the same hump around that frequency range. And I can confirm that nothing sounds really weird to me with the 400i (I'm actually kind of sensitive to frequency spikes in the mid and upper midrange, they just sound immediately weird).
Hope this answers your questions!
