The grill mod helps with the bass impact at the expense of some texture/definition.
The gain is about the same as the loss...
The grill mod helps with the bass impact at the expense of some perceived texture/definition.
I really like how honest you are... You could easily just say 'OMGWTF, moar soundstage, bettttterr!!!' and be done with it. I cannot say I heard more texture/definition in bass without grills (HE-4, HE-400, HE-500) but even then, I appreciate that you are trying hard to analyse the mod (as best as you can).
All I see is a very gentle slope down on the extreme upper mids, while MOST of the mids are the highest point of the 400i's sound aside from the lower treble peak. Sorry but, unless you only see mids as upper mids only, the 400i's mids are VERY much the dominant aspect of its sound. Mids are incredibly straight for the majority of the sound spectrum.
If you compare Tyll's, Purrin's and GoldenEar graphs for the same headphone, you'd get 3 very different curves.
No wonder a headphone can sound diffrently to diffrent persons if the measurements differ from each other. So each of us can pick his/hers favourite measurement as well...
If anyone is here wondering if this headphone is for them, feel free to check out my review, just posted today.
Where the review
I'll be keeping the demo pair HifiMan has sent me, and selling off my HE-400. Sure, bass isn't as good, but everything else is better including comfort.
After a few days of listening to the HE-400i alone, going back to the HE-400 was a huge shock. All it's deficiencies seemed to be multiplied. Vocals sounded more distant than I had remembered, and the treble just plain hurt in certain songs with no EQ of course.
It was at that point that I decided that I can't go back to it so I'll be buying the demo pair off HifiMan and getting rid of the HE-400.
Something else I'm noticing, and this is probably just my imagination, but bass seems to be hitting harder now and extending a little lower. Again, I'm probably just imaging it.
