wje
Unmodified = Not worth listening to.
Not sure if you guys have seen this, or if someone had posted it earlier.
It would appear that the HE-400i and HE-560 are now running the 1/2 magnet structure like the HE-4? This is what could attribute greatly to the lesser weight of the two models.
Source: http://stereos.about.com/od/Audio-Shows/ss/CES-2014-New-Audiophile-Headphones_3.htm
~~Every planar magnetic driver I've seen is a "sandwich" of two magnetized metal stators with a plastic diaphragm in between. When an audio signal passes through the wire voice coil that's applied to the plastic, the diaphragm moves forward and backward in the stators' magnetic field. The HE-400i and HE-560 differ in that they use just one stator per driver.
