ScottieB
- Jan 13, 2007
Hello. Today I put my Arya's down to go get some water, and when I put them back on my head, the right channel was no longer playing. After some trial and error I discovered that the cable is fine, the driver is fine, the amp and dac are fine, but the jack seems to be damaged. If I only plug the cable in part way, I get sound - but as soon as it 'clicks' all the way, the sound goes out.
I assume (and hope) this something to do with the soldering of the jack - or if not the jack itself can be replaced - because I am out of warranty and will need to attempt this myself. I can solder, so I'm good there, but I have never taken a planar headphone apart before; I've never even changed the pads on these Aryas. If anyone out there has any experience with the Aryas in this way or knows of any threads/videos anywhere I'd appreciate any info or links. I've done some searching but most of what I've found is about dead drivers - my driver works - but only when the cable is partially in.
Thanks.
Thanks.
