cirodts
- Jan 27, 2016
between stealth and organic which one do you prefer and why?
Did you use stock SE cable or your own balanced cable while listening? bth where to get good quality 4.4 balanced cable for these?After 70hrs (more or less) this are my impression..
There's more impact on the lower region, still maintain a good definition.
One of the most noticeable improvement is on depth, now the voice are placed correctly in front of you and over the other instruments.
I found the organic one of the most "chameleon" headphone in term of soundstage.
Is very track dependent, so can be very intimate and close sounding with some song or open and airy (even more than the stealth) with others.
High frequency doesn't bother me anymore, but it still a bright headphone.
All my listening was through an ess 9038pro, i assume that an r2r dac will be a best match for the organic.
I will wait to complete the burn-in before saying how the arya perform with instruments and different musical genres, since it has changed quite a lot from day 1.
That's all
For now...
BalancedDid you use stock SE cable or your own balanced cable while listening? bth where to get good quality 4.4 balanced cable for these?
The main vocal should be center (majority of mixes), if you are hearing too much to one side you most likely have some sort of channel imbalance.I remember sundara had a very marked right-left stereo effect and I liked it a lot, who of you tried arya stealth and organic, which of the 2 has a sound image more to the right and left instead of central?
Agree, very confused with Hifiman pricing, only $100 price differnce the Stealth may not be strict upgrade over the Organic. eager to see comparision between these two.Very interested in sound quality differencies reagrding the price beetween Arya Organic (1299$) vs HE1000 Stealth (1399$) ???
Here’s the GRAS measurements compared to Harman OE 2018Careful, this is a B&K 5128 setup measurement, not a GRAS setup. You cannot make a direct comparison with the usual Harman target - though I still expect it to be bright.
Stay updated on headphones.com at their sponsor profile on Head-Fi.
We need HEK Stealth measurements too.Here’s the GRAS measurements compared to Harman OE 2018
Full suite of measurements can be found here for both raw and compensated https://forum.headphones.com/t/hifiman-arya-organic-official-thread/21830
Arya Stealth have very centralized stage. It doesn't expand laterally. If you want more lateral sound, Organic or HEK Stealth might be better. I will receive my HEK Stealth soon. I can do a comparison.I remember sundara had a very marked right-left stereo effect and I liked it a lot, who of you tried arya stealth and organic, which of the 2 has a sound image more to the right and left instead of central?
Hope you guys publish HE1000 Stealth GRAS meaurement tooHere’s the GRAS measurements compared to Harman OE 2018
