Ah! This is something I don’t know about. But if the mesh is attached to the pad and you get the Dekoni pads, you won’t have any inner mesh. I wouldn’t do that personally, I know the reason they changed the material of the mesh from the V1 arya to the V2 was that they were having too many warranty replacements with the old mesh (which was more open).I read the issue is the rings used to attach the earpads aren't the same on non stealth versions? Seems to be based off one comment on YouTube. Just took mine off and it seems to have 9 clips on it. Inner mesh is on the pad
It sounds like you found the problem though! If I were you I’d write to Hifiman about it. I’m sure they’d send you a fresh (not deformed) set of pads to use with your specific model.
