They get even better with time, IMO.
I am certainly finding that to be the case. The presentation has become a notable amount more expansive as you said it would after the first 50, 75, to 100+ hours of use.
Put in a number of hours of listening time on the Arya SE paired with the new Burson and am really enjoying the combination so far. There are things I like about this unit, the sound it produces being the primary one, but there are a couple of minor things I am not crazy about, mostly to do with the unit itself. My time spent listening was divided up between some games on Xbox Series X, an episode of The Witcher S2 on Netflix, a couple of YouTube videos on my TV, the 1st half of the movie Fury on UHD, and listen to a couple hours of music from my iMac. This gave me a broad scope of the Arya/Burson pairing. I’m still reserving judgment until I have broken in the Burson more and listen to it a lot more, but I am likely going to keep the Burson and sell the Fiio. Nothing wrong with the Fiio in the slightest, especially given the price; it will still get my whole-hearted recommendation at its price point. The Burson C3XP however, appears to have improved upon the sound in just about every way over the K9 Pro and as it should, considering it’s effectively double the price.
Now I have to wait until I get home from work to do more listening.
You'll definitely find the V6 Vivid op amps burn in over time. The sound gets warmer, more punchy, and the treble tames down a good bit. Glad to see you're enjoying the pairing already!I’m still reserving judgment until I have broken in the Burson more and listen to it a lot more
That witcher show.....good gawd man. I stopped half way into s02e2. Its a mess. Gonna replay the game when the update comes out though. The soundtrack for the game is top shelf !
Did you listen to any music ? Being so new to all these products how would your immediate perception of the burson be compared to the fio ?
That’s awesome! As shoddy as their quality control can be at times, I’ve always found the responsiveness and care of their customer service to be top notch.So I contacted Hifiman and sent them pictures of everything and they're going to send me a new pair of ear cups!
I also have the Dekoni arriving soon so I'll be sure to test them bothThat is great to hear! Hope the new pair is much better for you!
Please keep us updated. My Hifiman cans got a similar problem. Will they send you new headphones or just parts?So I contacted Hifiman and sent them pictures of everything and they're going to send me a new pair of ear cups!
Email said "Rma for earpad" so should just be thatPlease keep us updated. My Hifiman cans got a similar problem. Will they send you new headphones or just parts?
Don't get me wrong, the Vivids are excellent - transparent, excellent timbre/tonality, and wide sounding, but just not as wide as some others I have on hand. Rolling opamps can be a way of essentially having a slightly "different" sounding amp by - and they're a whole lot cheaper than buying another amp to get a different sound. One must be careful to swap out opamps with others that are compatible and to also make sure you install them correctly - or else...let the smoke out on the opamp and/or the device. You could try Googling opamp rolling and you'll come up with a plethora of hits.I can't even wrap my head around opamp rolling yet... but trying to understand what you're saying, the V6 vivids, which apparently come standard on the Burson 3XP are not as wide... does anyone know if there's a handy dandy chart that compares different opamps? I think I recall seeing one just of the ones offered by Burson, but I'm curious...
And yep, this is the rabbit hole and I'm falling straight through the rabbit hole... haha
