As promised, I'm reporting back on my session comparing the Arya V2 and V3 today (sound only). It was quite a journey so bear with me.
Disclaimer, I loved both, but neither was perfect. I still haven't decided which I'll buy. I'll sit with the experience for a few days then decide. Maybe you kind folks can share which you'd go for based on the following recap? Here goes:
First impressions:
Arya V2 - brighter, even siblant at times (e.g. Losing my Religion, 2 mins in), bigger stage, less in your head, slightly less impactful bass (but still has great extension and rumble in sub-bass), slow decay in treble, more defined layering and separation (highly impressive but almost unrealistic at times). Imperfect timbre (but by no means bad, better than my first listen to the V2 a few weeks ago).
Arya V3 -Thicker more impactful bass, slightly narrower soundstage than V2, a bit more in your head in or at least closer. Slightly warmer, fuller sound, fractionally less siblant in Losing my Religion (but still siblant nonetheless). Less airy, less wow-factor.
At this point I was leaning clearly towards the V2 as my preference.
Then, enter the Susvara!
Added it to the mix mix as a reference (because, it's Susvara) and then I started to see what was happening (I think). Now, don't get confused, the Susvara is superior to the Aryas (and everything else I've ever heard) except for its soundstage, which is narrower than the V2. It's THE MOST RESOLVING headphone I've tried. I heard things in the Susvara that I've never heard in another set of headphones.
The stealth magnets construction of the V3 seem to bring it closer in sound signature to the Susvara than the V2 particularly, in terms of warmth, tonality and staging (but not detail and resolution).
I emphasise, do not expect Susvaras from the V3, just that you are closer to Susvara than V2, but that doesn't mean I prefer the V3. I'm torn and probably still leaning towards the V2. I love the airy-ness and wider stage of the V2. It made the experience more relaxing, enjoyable and unique for me. The V3 didn't feel special to me until I tested the Susvara and felt the V3 was a step in Susvara direction. The V3 does sound fuller through the bass and mid range, and perhaps a smidge more detailed than the V2 (but of course, not as detailed as the SusVs).
So those are my impressions. Let me know if any questions... And let me know which you'd choose based on those impressions cos I'm quite stuck now. This could be the last chance for me to get a new V2 so that is also a consideration in my mind.
(For craps and giggles I also threw my Gold Planar GL2000 into the mix to finally put that hype to bed in my own mind... It is I'm no where near the same league. Also tried out the focal Stellia - a totally different ball game and not worth saying more about that now.)
