Greetings Ananda-BT owners. I just received a pair of Ananda-BT headphones. I am not sure if I understand the charging process correctly. When I put the headphones in charging mode (Red LED light), the light never changes to blue. I left the headphones charging all day (more than 8 hours) and the red light never changed to blue to indicate the charging was complete. Is this a problem with my set or is this the same with your BT headphones too?
Hi.
Are you sure that you are doing it OK?
Red light should be blinking.
You have to power on and then press the charging button for a few seconds.
