jerg
- Aug 11, 2010
Thanks for the reply, I'm blocking the slits by 1mm or less in some places, but mostly not, is that too much? How can I tell?
Well the tolerance for errors is really low (the openings between the magnets are only about 4~5mm), even 1mm blockage is ~20% of the opening blocked. It's better that you cut the strips a tad thinner than wider relative to the magnet widths.
