- Oct 16, 2012
Just put up my Music-centric review! http://www.head-fi.org/products/hidition-nt-6pro/reviews/10111
Ops, my bad on the cable. However, I was assuming that the NT6 and NT6 Pro share the same stock cable options.
Does NT-6 Pro have better mids than UM Miracle? is the mids also behind the bass? or?
Nice review! Interesting note about the clarity vs. the JH13FP. I don't have the JH13FP, but from what I know, the clarity is similar.
Thanks! I noted they sounded similar but there's a tad bit more separation and clarity for me anyway with the NT6-Pro. It may also be the brightness but as with everything audio.... YMMV!
Does anyone know if there's a place to demo these in NYC or San Francisco, or any other USA metropolitan city?
Thanks!
Thanks!
Nope, unfortunately you have to purchase these "blindly" based on impressions from users online.
Thank you. If anyone has experience with the IEMs in my sig, which one is the NT6 Pro most similar and different to in terms of sound signature? Is there any other <$200 that has a similar signature? I know the quality will be very different, just trying to get a sense if this will work for me. Thank you.
Also, will Hidition be releasing any new products soon? What is their future plan to improve their IEMs?
Thanks!
They do almost everything right vs. a less expensive iem that does maybe one thing well.
My opinion of the NT6pros magic is their transparency and detail
Thanks everyone. I won't be using an amp, so it sounds like these and the SE 5 way won't work for me. So I may try the JH16 or JH13. Several HFers have mentioned the detail on the NT6 pro might be overwhelming to someone new to the high end. So not sure what to do...
