Hiby R6 Pro - serious upgrade to popular DAP
KarlAgathon
- Jul 3, 2010
- Messages
- 384
- Reaction score
- 41
Hello and thank you for replying. My apologies for not being more specific.Hiby OS player? If you mean System / Wireless update, that works on my R6 Pro.
Not referring to firmware updates through the main menu.
Referring to check for updates within the music player. OK maybe it’s not called the music player, but it’s the only thing I can think of at the moment.
jsmiller58
Thanks for the clarification. I don‘t use the HiBy music player. But I just checked (HiBy Music R6Pro International Edition 1.6.0) and the Update Check button in the About menu item is indeed unresponsive.Hello and thank you for replying. My apologies for not being more specific.
KarlAgathon
- Jul 3, 2010
- Messages
- 384
- Reaction score
- 41
Thank you for confirming.Thanks for the clarification. I don‘t use the HiBy music player. But I just checked (HiBy Music R6Pro International Edition 1.6.0) and the Update Check button in the About menu item is indeed unresponsive.
LCMusicLover
Active for me. I am currently downloading 1.5.2.6031Thank you for confirming.
Cactus108
- Feb 6, 2013
- Messages
- 123
- Reaction score
- 20
Problem is I got a replacement unit, albeit used from musicteck and that jack also failed. Both units had jacks that failed so I just figured they weren't built to be very robust.I have many IEMs and headphones and never had any issue out of my stainless steel R6 Pro - either SE or balanced.
Clearly you have a defective unit. Contact HiBy.
KarlAgathon
- Jul 3, 2010
- Messages
- 384
- Reaction score
- 41
I’m on 1.6.0 of Hiby music on the R6 Pro (2018 International version)Active for me. I am currently downloading 1.5.2.6031
Remember, I’m not referring to the main firmware of the player. I’m specifically referring to the music player bundled with it.
LCMusicLover
I got that. I expected that I would do that install and then report whether my update button deactivated. But instead, the update broke HibyMusic. With that version installed (1.5.2) HibyMusic won’t even run — error message says it started and then immediately stops again, grrrh!I’m on 1.6.0 of Hiby music on the R6 Pro (2018 International version)
gLer
Either that's pure bad luck or you got your original (unfixed) unit back.Problem is I got a replacement unit, albeit used from musicteck and that jack also failed. Both units had jacks that failed so I just figured they weren't built to be very robust.
