Nailzs
- Jul 8, 2007
Question about the Hiby player. In the title listing some have a yellow box with the letters HR in it and others don't. What is that?
qpoHello,
I bought an R6 Pro from someone on eBay, but it appears to be a Chinese version without the Play Store. Is there a way to get the Play Store onto the device by either installing it or by flashing the International firmware onto my device?
So, I finally completed install and downloaded my library. Happy to report that Tidal 2.11.3 works precisely as it is supposed to - first unfold happens correctly in on line and off line mode, reporting either 96K or 88.2K as appropriate for MQA files. I am definitely keeping Google Play Store auto update off until I hear that the compatibility between the R6 Pro and Tidal has been worked out...What version of Tidal does a better job of unfolding MQA ?
I see you on HBB discord. Thanks Jim for your help.
I like my S8F's better unbalanced since the hiss is less then 4.4mm .
Does the color of the LED on the power button give a clue? It should change based on the sample rate...Question about the Hiby player. In the title listing some have a yellow box with the letters HR in it and others don't. What is that?
Yes they are. It seems my .ape rips aren't. I guess I'll have to redo them.That should indicate those files are Hi-Res. Are they 24-bit or higher?
None of my music rips are over 24bit so the LED doesn't/hasn't changed color from blue.Does the color of the LED on the power button give a clue? It should change based on the sample rate...
Here is the info I got from Hiby...
The lighting scheme for the LED for different sample rates are supposed to be as follows:
Not playing: pale blue
32-48kHz: blue
88.2kHz-192kHz: green
352.8-384kHz: orange-yellow
DSD: white
You're streaming that file?For example, here's a 176.4k file playing from my local library, and she's lit up nice and green.
You sure it’s not the hiss from the recording itself? I don’t detect ant hiss issue with highly sensitive earbuds .So, I finally completed install and downloaded my library. Happy to report that Tidal 2.11.3 works precisely as it is supposed to - first unfold happens correctly in on line and off line mode, reporting either 96K or 88.2K as appropriate for MQA files. I am definitely keeping Google Play Store auto update off until I hear that the compatibility between the R6 Pro and Tidal has been worked out...
On the hiss issue... yeah, I think I described it as sounding like a basket of snakes... IEMatch works well, but a lot of times I just play music loud enough to just not notice except in the gaps...
Good to see you on Head-Fi as well!
