Hello.
I am trying to install custom theme on my R3 Pro.
Theme:
https://github.com/7490212774519684/ipod-revival-modern
Instruction:
https://github.com/7490212774519684/ipod-revival-modern/wiki/installation
Windows 10 64 bit.
I am currently on 1.5 firmware.
I've installed all required data from here:
https://drive.google.com/drive/folders/1d8hAzMUYp4aBZNs04__Za6pRcaT7vhnp
My first problem: looks like liteGUI.exe program is not starting on my machine. When accessing as in manual via r3pro.bat file, executable window is opening for a short time and automatically closes. I've checked .bat commands and found that it is starting liteGUI.exe I've got two missing dll files: "ssleay32.dll" as first and "vld_x86.dll" as second. Both files were downloaded from the net and placed in the C:/Windows directory, second was placed into C:/Windows/SysWOW64. After all, liteGUI.exe is still not starting, now I've got error saing that "application was not propelry started" with error code 0xc000007b.
Any suggestions?
Edit:
Okay I've found a solution for running r3pro.bat file in Youtube:
Okay after a day or two i figured it out for the HiBy R3 Pro for the r3pro.bat and Theme compression pack.bat to work.
1. copy and paste the contents of
\r3pro_en_simulation_v1.0\【03】Instruction directory\data
and paste into
\r3pro_en_simulation_v1.0\í+03í+Instruction directory\data
2. Rename the folder (í+03í+Instruction directory) (i know it says not to but do it)
3. Then navigate to Theme compression pack.bat
\r3pro_en_simulation_v1.0\í+04í+Compressed theme pack\(2) Compressed theme pack
right click and edit Theme compression pack.bat (using notepad)
4. Find
set base_dir="../../¡¾03¡¿Instruction directory"
and rename
to the name of the folder from step 2.
save and exit.
You should be able to run Theme compression pack.bat now.
check your custom skins with r3pro.bat
and make sure to change Version.txt keep as 1.0 to check with r3pro.bat (litegui/emulator)
then change to your device version when ready to install theme on device and run Theme compression pack.bat again for you .t file
Source (it is a comment of
0000Quanta user to the Hiby Music guide video):
Unfortunatelly ipod-modern theme is not working with my device. Maybe it is not compatible with 1.5 firmware? Would someone be so kind and check on other device / firmware, please?
