zerogun
- Mar 28, 2008
I have the original R3Pro. No real problems with Tidal nor Qobuz (I have both) streaming at highest bitrate. Very rarely I'll have a hiccup on Qobuz on extremely high bitrate tracks, but then again, my home internet is a cellular hotspot so speed isn't always consistent. OTOH, Tidal's MQA files are actually a significantly lower bitrate and I've yet to have one of those hiccup or stutter while playing.
Have you noticed if it only seems to do it on certain tracks/albums? Have you tried the same tracks on your phone or computer? If that's the case, I'd be happy to try them and see if they play ok for me.
[edit] Oh - another thought - are you listening via wired headphones? or Bluetooth? If bluetooth, is your WiFi 2.4 or 5 GHz? Bluetooth also operates in the 2.4 GHz band, and it is possible for BT and WiFi to interfere with each other in some circumstances. Also, are you on the latest firmware?
Thanks for the detailed responses MrNaturalAZ and purplesun! I've experienced it with different tracks and with both wired and BT headphones. I use a mesh network so that seems to be the culprit here! I am on the latest firmware too for my Hiby R3, but I don't recall this happening if I'm streaming off my Macbook Pro for example... I guess I'll have to just keep monitoring this.
