Acreo Aeneas
- Sep 23, 2007
Those aren't the normal issues which require you to update the recovery, that's normally only required if the player simply reboots when attempting to flash firmware. I'd recommend putting firmware on freshly formatted SD card, an old one will do if you have one spare and retry. If it doesn't work then follow the steps above and Hiby have shared to flash recovery and then should be able to update fine if there is an issue upgrading firmware normally.
I just tried updating the firmware again using a smaller 2 GB FAT32 microSD card. The player just reboots and doesn't actually update.
So this means I need to try this other recovery method?
Is there a detailed guide on how to do this update via the recovery method? What files/drivers do I need and where do I download them?
