MrNaturalAZ
- Jun 6, 2014
If anybody's interested in a radio.txt file with 286 verified working stations (including SomaFM, 181.fm, and more) see this post.
Only european reseller is german and sells only in germany. Otherwise you have to wait until they put it on amazon uk or else just order from the site. I was waiting for amazon, but since i waited months and there's still to wait cause of covid, i decided to get it from the site! It only took 2 weeksHi guys. Any european reseller? Or a used one in mint condition?
Does this player has FM radio?
Have just listed mine for sale alongside chord mojo and 3D printed case
This is an amazing combo.How was your sound experience with that....i am building the same set up
I have been using it for over a year, and I call it my little “sound brick”
The Mojo is really good especially with live recordings of acoustic music, it reproduces soundstage, timbre and dynamics extremely well.
And the R3 is a nifty little player with nice user interface and pairs perfectly with the Mojo.
The weak point is the Mojo’s micro-USB connector, which is simply not designed for frequent connecting/disconnecting and needs some protection. The other weak point is the RFI the Mojo picks up when stacked with the R3 with enabled Wifi.
The 3D printed case and transport box make it super robust though, and just today I reworked the lid of the box for easier printing.
With that combo box I just throw the stack into my backbag or suitcase without ever worrying, and the compact cabling is also pretty robust.
I have the coaxial 3,5mm and the micro-USB, and according to Rob Watts and my experience the micro-USB is better.Thank you for your info!!!
Another question.... i have ordered the the type c to coaxial cable... there will be any difference?
Also tha mojo gets hot after long time of playing. attaching them together and with a silicon case , wouldnt increase more the heat?
Yes mojo is bad with RF waves...i had tha problem with mobile..
