ADUHF
Headphoneus SupremusMusic And Measurements
The 350$ for everything makes it really tough.
There is only one thing that comes to my mind and that would be something like a FiiO E17 or similar.
If you would need the EQ only for music, then you could get the USB Audio Player Pro on an android Device as source. The parametric EQ costs like 5$ and is really good from what I've heard. However then you still wouldn't have EQ for the other sources.
Honestly the cheapest solution I could imagine which I'd still call "audiophile" would be the entry Schiit Stack Magni + Modi + Loki. However that stack alone costs 350$ and you don't have anything left for a headphone.
Thank you for the reply, ThanatosVI.
The price is a bit of a problem. If my mixer was still working, for example, then I could maybe just get the DAC and amp, and temporarily use the mixer as my EQ. But everything decided to break on me all at once.
I like the idea of a more modular arrangement like you describe above. Because that would potentially allow me to upgrade each piece as I'm able, and as I find better gear that I can afford. But I'm pretty much limited to what I can do along those lines to what's available through Best Buy and Guitar Center, for the time being. I welcome any other suggestions that you, and gimmeheadroom, and others have though on that. Or on some of the other approaches discussed above.
I spoke with a salesman from Sweetwater today to see if they had any ideas on my situation. And they also suggested the RME DAC/headamp (which is out of my price range). And also mentioned the Grace Design m900, and walnut Klipsch Heritage Headphone DAC/Amp. Both are in the $500-600 range. And both have TOSLINK optical inputs. It doesn't look like either one have built-in EQ or tone adjustments though. The unit by Grace Design has a digital interface though that allows you to add crossfeed, and adjust the L/R channel balance, as well some different filtering options for the digital inputs. So I may look at some of their other products to see if they have something else I could use. Perhaps they could add some EQ features to the m900's digital inputs via a future firmware update as well(?). Not sure about that though.
The Grace Design m900 uses an AKM 4490 DAC, and the Klipsch uses an ESS Sabre32 DAC btw.
We also talked briefly about interfaces and some of the other hardware options, but that didn't yield too much new info. My next step is probably to go back through all the options via Guitar Center or Best Buy, now that I have a somewhat better idea of the kind of thing I'm lookin for, to see what I can maybe cobble together from those two places.
Thank you both for the help again. It is much appreciated.
