bimalh
- Dec 19, 2005
Looking for recommendations for two pairs of CLOSED Headphones. Source will be iPods. Closed headphones which does not need amplification.
My daughter she listens to current Top 100 kinds rock/pop/r&b genres. She would be taking them everywhere. She is 11. The budget for her headphones is between $50 to $100
I need pair of closed headphones for my office and travel. Really don't need noise canceling but I don't want sound to leak out and disturb my colleagues. My budget is upto $200. I want something that can be driven by just an iPod with no Amp. I do listen to bass heavy stoner rock so I don't want the cans to add more to the bass like the Dr. Dre cans but should be able to handle heavy bass. I also listen to voices like Natalie Merchant, Kasey Chambers, Jem etc too. So the headphones needs to reproduce both ends of the spectrum without adding or taking anything from it.
I look forward to your advice and Thank You.
