Aviv
- Jan 31, 2015
Bump, need answers for today if possible
It appears from what I can tell that your motherboard has PCI-Express slots that would work with the DGX. But you should double check the manual.
The Xonar DG/DGX is the best sound card choice in your budget range.
Although, in the soundcard site, it says that it's a special soundcard for gaming, do you think it will satisfy me while producing and hearing music and I will not have any more problems with the sound and volume like I have now? Also, I saw that it powers 10Ohm headphones, and mine is 32Ohm, shouldn't that be a problem?
As I already said, the DGX (or DG) is the best sound card choice in your budget range. My recommendation again would be to wait and save your money for six months or a year and get the FiiO E10K.
Great, the DGX is the one that sold in my country.
I would get HD681B instead of HD681 since the latter can be fatiguing.
You have PCI-E X1 slots, which will work fine with the Xonar DGX.
What is the difference between them?
HD681B is a balanced version of 681. More pleasant to listen to.
How about an Asus Xonar DG or DGX? These are internal sound cards that can often improve on motherboard sound.
Onboard sound might have weak volume you are experiencing, dedicated soundcards usually go louder even though those are not marketed as having an amp in them. But like I said, onboard sound has evolved a lot over the years...
Xonar dg would be better than fiio e6 because it would give you a good dac with it too. Since you can't get your pc to run headphones loud enough it is hard to tell if the dac on it is decent. Most phones for example have decent dac's in them these days, not so much the case with old pc's with onboard sound. My headphones are barely loud enough on my phone but still the sound is better than on my laptop which gets louder. Bass is fuller on my phone etc... So amplifying is not all that matters. Amplifying bad source signal will just get you bad sound but louder. Of course it is impossible to say if it is the case with your gear but it is a possibility.
installing a soundcard is not that difficult. Check out this video https://www.youtube.com/watch?v=GsDpEuIl1EE
I am in a bit of dilemma now though, I currently have 2 choices after I will get refunded for my broken HD681 Evo:
1) To get another pair of these headphones instead of refund, but without any warranty from eBay (which means chance of getting broken pair again), and to wait another 2\3 weeks.
2) As soon as I will get the refund - to buy the HD681B which is sold in my country for 50NIS less than the Evo's, and with 1 year warranty.
Which option should I choose comparing the difference in quality of these 2 headphones?
Thanks!
You already know you like the sound of the Superlux HD681 Evo. Unless you can listen to the HD681B, no guarantee you will like them better or even as well. So seems like this is a decision you have to make on your own.
I would add that if an Ebay seller sends you a broken item, it is more than fair to ask them to inspect the replacement pair that they send you prior to shipping it out. Ebay sellers with good ratings are typically more than happy to do something like that on a replacement. They don't want to get feedback like "original returned and the replacement pair were both broken."
