jasgre2000
- Feb 4, 2010
I bought a set of Sennheiser HD 238s over a year ago. I really liked them a lot. Unfortunately, while using them on a plane I accidently bent the plug and it broke. I figured I could replace it with a plug from Radioshack and a soldering iron. I have tried a couple times now and have had no success. The wires on the HD 238s are very thin and coated with lacquer. I tried to melt it off with solder, but it didn't work. I would really like to fix them. Has anyone here replaced a plug on the HD 238s? Any suggestions on how to get the lacquer off? I tried to solder them to the plug without removing the lacquer and they wouldn't work. Any other suggestions on how to fix these?
Also, is it a good idea to get a better plug than just the generic one from Radioshack? If so, any suggestions for a reasonably priced one?
