If it says sb, it's probably not unzipped. download 7-zip, unzip to a new folder on your desktop where you can find it and then open the StUpdaterApp_4MIN which is it's own installation program and go from there. You don't open the firmware.sb file. It will be used automatically if you run the program correctly. After you reset the unit, you need to hold down one of the buttons as you connect to your PC but I forget which one. Read the instructions on formatting etc before starting. If not given, look in the sponsor forum about the -p version for more info.
You can PM me if you need.
Okay, wow thanks for coming to my rescue! But I think this is gonna be a bigger can of worms than I expected. Maybe I should just leave the BA off and use the Dynamic.
No, I did unzip the file and was presented with 2 .sb files, 2 word docs with instruction in JapaNOTease, and the .exe app that you referenced.
When I click on the install app I get a firmware window that SHOULD give me the sys config of my device. But it is blank. It shows the firmware it wants to install. And keeps asking me to connect my device, which is obviously connected. Device is USB connected and shows in my computer as Hisound and is accessable. But doesn't show as connected to upgrade firmware. Which may be good after all because from the pretty japanese word.doc pictures it says to check boxes: "Format Data Area" and "Full Media Erase". ACK!! Is this installation gonna add to device, or is it gonna sacrifice my entire system, Dynamic firmware, and library?
A few times during install attempts I got "cannot open .sb file" errors. But I think you are right in that the install.exe app should take care of those files.
So what do you think? Should I just foo foo the BA firmware and be happy with only the Dynamic? It just annoys me that I paid too much to not have a fully functioning , all the bells and whistles DAP.
FYI, the reset buttons to use when connected to the computer are the middle and the one above it at the same time. Though I do not know fully what this will wipe, or will it be just be a hard reboot when the reset buttons doesn't do the job.
Thank you for your time, attention, and expertise; and I look forward to any more words of wisdom you may have for me. Thanks!!
