MTL
- Jan 19, 2004
As I just received the Heed I bought from Minivan, and someone in another thread on HeadFi asked for a short comparison with the Lehmann black cube linear, which is the amp I do usually use, I thought I might just as well post my findings here as well:
So, after a first listening session with the Heed against the Lehmann bcl (source was my Primare CDP D20, headphones were AKG K701 and Grado PS1, music was instrumental and vocal jazz) it's quite obvious that the Lehmann is the superior amp (and it better should be, considering the difference in price...): It's less euphonious - or colored, if you will - more matter to fact and shows more details, has better control and really tidies things up compared to the Heed that tends to 'muddle' things together when the music gets a little more complex. Furthermore when you switch to the Lehmann, it's as if a thin, foggy curtain is removed from the music: everything seems clearer and closer to the real thing (especially acoustic piano!). So, sonically it's really another league, as it is built-wise, btw, and the switchable gain feature of the Lehmann (0/10/20 dB, switchable unerneath the unit) makes it extremely versatile imo. The second headphone out isn't bad either... (bottom line: if you ever get the chance to listen to the Lehmann you may be quite delighted).
Interesting also that the Heed runs far more hot than the Lehmann (maybe that's why it sounds 'warmer' in general???
) and that while listening to the Heed I got a noise from switching on the Lehmann but not vice versa.
Btw - I didn't think the soundstage was considerable wider on the Heed (something it got praised for especially) than it was on the Lehmann.
Next step will be the comparison to the Meier Corda HeadFive and the Aria... and then, once it's here, with the Green Solo, which I then of course will also compare to the Lehmann!
